I recently got a raspberry pi zero 2 W and tried setting up pihole on it. I run on Raspberry Pi OS Lite (64-bit) - Debian Bookworm
When trying to connect to the admin page with either IP address or pi.hole/admin, I end up on an unknown page where the adress is not recognized. I have added the pihole IP as static and added it as IPv4 DNS
Your debug log shows you have lighttpd running on your system and using port 80:
[β] tcp:0.0.0.0:80 is in use by lighttpd (https://docs.pi-hole.net/main/prerequisites/#ports)
[β] tcp:[::]:443 is in use by pihole-FTL
[β] tcp:[::]:80 is in use by lighttpd (https://docs.pi-hole.net/main/prerequisites/#ports)
Your log also shows Pi-hole is configured to use ports 80 and 443:
[webserver]
port = "80o,443os,[::]:80o,[::]:443os"
At the moment, you can access Pi-hole web interface via https: https://192.168.1.78/admin, without any changes.
If you want to access via http, you need port 80 free, or you need to change Pi-hole's ports.
How to do it:
Method 1:
Pi-hole v6 doesn't use lighttpd.
If you don't need lighttpd for other web services, you can uninstall lighttpd and restart Pi-hole:
This will free up port 80 and restart Pi-hole web server and you will be able to access Pi-hole with http://192.168.1.78/admin or http://pi.hole/admin. https will still be available.
Method 2:
If you want to keep lighttpd, you can just change Pi-hole ports using this command:
