Unbound shouldn't be blocking traffic from api.met.no
I'm running Pi-Hole on a Raspberry Pi Zero 2W and it's running absolutely fine for the most part, but I can't get the weather in my Home Assistant to show up and tracing the problem, it's because Unbound is blocking the API call as BOGUS
If a browser is on your network and you want Pi-hole to block ads for all network clients, the browser should also be using Pi-hole for DNS resolution. Pi-hole, in turn, uses unbound.
Sorry, that's just too much for me. The browser works properly and is blocking everything Pi-Hole tells it too. It's just when it comes to api.met.no there's an anomaly. I feel like we're going in the right direction with this algorithm 10 stuff. Can you explain it like I'm 5 how to whitelist algorithm 10? The link to the docs is going right over my head and I feel like I'm likely to create more issues than solve them if I try and blindly fumble around in them.
So it fails on retrieving the A record already, i.e. before DNSSEC validation.
Also note that we have queried your unbound at 127.0.0.1#5335 directly, confirming this as an unbound issue rather than a Pi-hole one.
Please check and share your unbound configuration:
Sorry, I'm an actual idiot sandwich, so not only did I not get a notification because I never turned them on. I also don't know how to quote properly either.
unbound-checkconf: no errors in /etc/unbound/unbound.conf
This is unrelated to the issue you are having with your specific instance of unbound.
Unbound isn't blocking the domain, and neither is Pi-hole. Unbound is unable to authenticate the DNSSEC signature of the domain, and thus returns BOGUS.
The domain has a valid DNSSEC signature (as evidenced by the fact that others can resolve the domain using unbound). That leave us to figure out why your local instance of unbound cannot resolve it.
There are additional tools available, but will require some study of the various outputs.
You can raise the verbosity of your unbound install to 5, query unbound directly for resolution of the domain, and then compare your log output to the output of a separate install of unbound that is able to resolve the domain. This online tool uses unbound and will show you the details of the log for that domain:
Select the A query type, type in your domain and hit query. The output will look something like this (just the first bit shown here):
Query results for A api.met.no
Response:
;; opcode: QUERY, status: NOERROR, id: 28876
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 1
; EDNS: version 0; flags: do; udp: 1232
;api.met.no. IN A
api.met.no. 0 IN A 157.249.81.141
api.met.no. 0 IN RRSIG A 10 3 300 20241212114207 20241112114207 488 met.no. mMuBn8XLCD9NBQEquN9xFFUL94tbjaKRfm1Ww52SnFrkwb9U1j30EJQhQziEesS2zQpy34g+PpndqAxZ6jUEN2aFAVsBmfXVBhUqx+1U3hsCuXsNaFCt1KtgzTXwdpt1wwu7XUEUYVojGHmYpEea1lXypuM1unM/I48CNRw9fYvE6adIPMC+HCrOPlF7KBxU3+NMb3tpviSZIlBR/JKAuNAyG3Hnnx/JTY9kix/NvQcdpV+3I/S2BIXU8FooLacZ1jHjdXWsy3M1MdDWd/6sqB65kPAor0w/tMkLj1QVtKCVgOoey6WXTga/M9nmoBhbBVbR/QXM9zDtPh6ULSGcJQ==
----- Unbound logs -----
Nov 12 15:41:09 unbound[9960:0] debug: creating udp6 socket ::1 1053
Nov 12 15:41:09 unbound[9960:0] debug: creating tcp6 socket ::1 1053
Nov 12 15:41:09 unbound[9960:0] debug: creating udp4 socket 127.0.0.1 1053
Nov 12 15:41:09 unbound[9960:0] debug: creating tcp4 socket 127.0.0.1 1053
Nov 12 15:41:09 unbound[9960:0] debug: chdir to .
Nov 12 15:41:09 unbound[9960:0] debug: switching log to stderr
Nov 12 15:41:09 unbound[9960:0] debug: module config: "validator iterator"
Nov 12 15:41:09 unbound[9960:0] notice: init module 0: validator
Nov 12 15:41:09 unbound[9960:0] debug: validator nsec3cfg keysz 1024 mxiter 150
Nov 12 15:41:09 unbound[9960:0] debug: validator nsec3cfg keysz 2048 mxiter 150
Nov 12 15:41:09 unbound[9960:0] debug: validator nsec3cfg keysz 4096 mxiter 150
Nov 12 15:41:09 unbound[9960:0] notice: init module 1: iterator
Nov 12 15:41:09 unbound[9960:0] debug: target fetch policy for level 0 is 3
Nov 12 15:41:09 unbound[9960:0] debug: target fetch policy for level 1 is 2
Nov 12 15:41:09 unbound[9960:0] debug: target fetch policy for level 2 is 1
Nov 12 15:41:09 unbound[9960:0] debug: target fetch policy for level 3 is 0
Nov 12 15:41:09 unbound[9960:0] debug: target fetch policy for level 4 is 0
Note also that we aren't unbound experts here. We have a guide for unbound and many of us use unbound, but that's generally where our expertise ends.
By troubleshooting, I mean you have run all your test commands, have the output you want to review, and are ready to return unbound back to its prior configuration.
Tried again with the correct command. Told you I'm an idiot!
dig api.met.no @127.0.0.1 -p 5335 ;; communications error to 127.0.0.1#5335: timed out
;; communications error to 127.0.0.1#5335: timed out ;; communications error to 127.0.0.1#5335: timed out
; <<>> DiG 9.18.28-1~deb12u2-Debian <<>> api.met.no @127.0.0.1 -p 5335
;; global options: +cmd ;; no servers could be reached
