My pi was actining weird so today I have reset everything, fresh install from raspberry pi builder, fresh install of pihole & teleported my settings in and all is working fine....
now id never used unbound before but I like the idea of it so though after seeing how simple it looks to setup tried following this guide, not sure if its ok to post here, if not please feel free to delete
fresh install latest Raspeberry Pi & Pihole - no other apps
when i run install of unbound i get the errors below.... im wondering as i found something called avahi already listening on 5353 do i even need that with pihole? (i read it comes as default with pi install?)
Linux raspberrypi 5.10.82-v7+ #1493 SMP Wed Dec 1 11:35:18 GMT 2021 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Thu Dec 2 12:11:59 2021 from 192.168.99.108
pi@raspberrypi:~ $ sudo apt install unbound
Reading package lists... Done
Building dependency tree... Done
Suggested packages:
apparmor
unbound
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 744 kB of archives.
After this operation, 3,966 kB of additional disk space will be used.
Get:1 http://raspbian.mirror.uk.sargasso.net/raspbian bullseye/main armhf unbound armhf 1.13.1-1 [744 kB]
Fetched 744 kB in 6s (131 kB/s)
Selecting previously unselected package unbound.
(Reading database ... 42275 files and directories currently installed.)
Preparing to unpack .../unbound_1.13.1-1_armhf.deb ...
Unpacking unbound (1.13.1-1) ...
Setting up unbound (1.13.1-1) ...
Job for unbound.service failed because the control process exited with error code.
See "systemctl status unbound.service" and "journalctl -xe" for details.
invoke-rc.d: initscript unbound, action "restart" failed.
Active: activating (auto-restart) (Result: exit-code) since Thu 2021-12-02 12:57:34 GMT; 77ms ago
Docs: man:unbound(8)
Process: 6279 ExecStartPre=/usr/lib/unbound/package-helper chroot_setup (code=exited, status=0/SUCCESS)
Process: 6282 ExecStartPre=/usr/lib/unbound/package-helper root_trust_anchor_update (code=exited, status=0/SUCCESS)
Process: 6285 ExecStart=/usr/sbin/unbound -d -p $DAEMON_OPTS (code=exited, status=1/FAILURE)
Process: 6286 ExecStopPost=/usr/lib/unbound/package-helper chroot_teardown (code=exited, status=0/SUCCESS)
Main PID: 6285 (code=exited, status=1/FAILURE)
CPU: 205ms
Processing triggers for man-db (2.9.4-2) ...
pi@raspberrypi:~ $ netstat -a | less
pi@raspberrypi:~ $ unbound-checkconf
unbound-checkconf: no errors in /etc/unbound/unbound.conf
pi@raspberrypi:~ $ udo grep -v '#\|^$' -R /etc/unbound/unbound.conf*
-bash: udo: command not found
pi@raspberrypi:~ $ sudo grep -v '#\|^$' -R /etc/unbound/unbound.conf*
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:forward-zone:
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf: name: "."
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf: forward-addr: 208.67.222.222
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf: forward-addr: 208.67.220.220
/etc/unbound/unbound.conf.d/root-auto-trust-anchor-file.conf: auto-trust-anchor-file: "/var/lib/unbound/root.key"
pi@raspberrypi:~ $ sudo netstat -nltup | grep 'Proto\|:53 \|:5053 \|:5353 \|:5335 \|:8953 \|:67 \|:80 \|:471'
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 127.0.0.1:4711 0.0.0.0:* LISTEN 570/pihole-FTL
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 528/lighttpd
tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN 570/pihole-FTL
tcp6 0 0 ::1:4711 :::* LISTEN 570/pihole-FTL
tcp6 0 0 :::80 :::* LISTEN 528/lighttpd
tcp6 0 0 :::53 :::* LISTEN 570/pihole-FTL
udp 0 0 0.0.0.0:53 0.0.0.0:* 570/pihole-FTL
udp 0 0 0.0.0.0:5353 0.0.0.0:* 308/avahi-daemon: r
udp6 0 0 :::53 :::* 570/pihole-FTL
udp6 0 0 :::5353 :::* 308/avahi-daemon: r
It would seem you just completed the first step of the guide (i.e. sudo apt install unbound).
I'd ignore the error for now and continue with Configure unbound from the guide.
(Also note that avahi (5353) and unbound (5335) would run on different ports if you follow our guide)
ah great thankyou!! seems to be working but when i do a "whats my dns server test i get
| US |
OPENDNS - Cisco OpenDNS, LLC |
208.69.34.64 |
| US |
208.69.34.65 |
im guessing something to do with Disable resolvconf for unbound (optional) section?
Last login: Thu Dec 2 13:20:59 2021 from 192.168.99.108
pi@raspberrypi:~ $ sudo systemctl disable unbound-resolvconf.service
pi@raspberrypi:~ $ sudo systemctl stop unbound-resolvconf.service
pi@raspberrypi:~ $ sudo systemctl restart dhcpcd
pi@raspberrypi:~ $ cat /etc/resolv.conf
# Generated by resolvconf
nameserver 208.67.222.222
nameserver 208.67.220.220
pi@raspberrypi:~ $
What's the output of:
sudo grep -nv '#\|^$' -R /etc/unbound/unbound.conf*
thanks i had just gone through and disabled the
I also edited the resolv.conf file putting a # before the nameservers and saving it then restarting the service (but i still get open dns when i test)
have ran your command and shows below
Using username "pi".
pi@192.168.65.252's password:
Last login: Thu Dec 2 13:30:52 2021 from 192.168.99.108
pi@raspberrypi:~ $ sudo nano /etc/resolv.conf
#nameserver 208.67.222.222
#nameserver 208.67.220.220
pi@raspberrypi:~ $ sudo service unbound restart
pi@raspberrypi:~ $ sudo grep -nv '#\|^$' -R /etc/unbound/unbound.conf*
/etc/unbound/unbound.conf:10:include-toplevel: "/etc/unbound/unbound.conf.d/*.co nf"
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:3:forward-zone:
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:4: name: "."
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:5: forward-addr: 20 8.67.222.222
/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf:6: forward-addr: 20 8.67.220.220
/etc/unbound/unbound.conf.d/root-auto-trust-anchor-file.conf:1:server:
/etc/unbound/unbound.conf.d/root-auto-trust-anchor-file.conf:4: auto-trust-an chor-file: "/var/lib/unbound/root.key"
/etc/unbound/unbound.conf.d/pi-hole.conf:1:server:
/etc/unbound/unbound.conf.d/pi-hole.conf:4: verbosity: 0
/etc/unbound/unbound.conf.d/pi-hole.conf:6: interface: 127.0.0.1
/etc/unbound/unbound.conf.d/pi-hole.conf:7: port: 5335
/etc/unbound/unbound.conf.d/pi-hole.conf:8: do-ip4: yes
/etc/unbound/unbound.conf.d/pi-hole.conf:9: do-udp: yes
/etc/unbound/unbound.conf.d/pi-hole.conf:10: do-tcp: yes
/etc/unbound/unbound.conf.d/pi-hole.conf:13: do-ip6: no
/etc/unbound/unbound.conf.d/pi-hole.conf:17: prefer-ip6: no
/etc/unbound/unbound.conf.d/pi-hole.conf:24: harden-glue: yes
/etc/unbound/unbound.conf.d/pi-hole.conf:27: harden-dnssec-stripped: yes
/etc/unbound/unbound.conf.d/pi-hole.conf:31: use-caps-for-id: no
/etc/unbound/unbound.conf.d/pi-hole.conf:35: edns-buffer-size: 1472
/etc/unbound/unbound.conf.d/pi-hole.conf:39: prefetch: yes
/etc/unbound/unbound.conf.d/pi-hole.conf:42: num-threads: 1
/etc/unbound/unbound.conf.d/pi-hole.conf:45: so-rcvbuf: 1m
/etc/unbound/unbound.conf.d/pi-hole.conf:48: private-address: 192.168.0.0/16
/etc/unbound/unbound.conf.d/pi-hole.conf:49: private-address: 169.254.0.0/16
/etc/unbound/unbound.conf.d/pi-hole.conf:50: private-address: 172.16.0.0/12
/etc/unbound/unbound.conf.d/pi-hole.conf:51: private-address: 10.0.0.0/8
/etc/unbound/unbound.conf.d/pi-hole.conf:52: private-address: fd00::/8
/etc/unbound/unbound.conf.d/pi-hole.conf:53: private-address: fe80::/10
pi@raspberrypi:~ $
updated after editing i # out the 2 nameservers, but now no dns is working lol
pihole shows as bogus
|2021-12-02 13:42:19|A|www.google.com|192.168.65.23|OK, sent to localhost#5335
BOGUS|
/etc/unbound/unbound.conf:10:include-toplevel: "/etc/unbound/unbound.conf.d/*.conf"
/etc/unbound/unbound.conf.d/root-auto-trust-anchor-file.conf:4: auto-trust-anchor-file: "/var/lib/unbound/root.key"
pi@raspberrypi:~ $
thanks after i removed those nameservers... DNS doesnt resolve at all and pihole reports "bogus"
i also now get serverfail for both the dig tests (unless i add those 2 opendns nameservers in)
pi@raspberrypi:~ $ dig sigfail.verteiltesysteme.net @127.0.0.1 -p 5335
dig sigok.verteiltesysteme.net @127.0.0.1 -p 5335
; <<>> DiG 9.16.22-Raspbian <<>> sigfail.verteiltesysteme.net @127.0.0.1 -p 5335
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 34634
;sigfail.verteiltesysteme.net. IN A
;; Query time: 0 msec
;; WHEN: Thu Dec 02 13:47:54 GMT 2021
;; MSG SIZE rcvd: 57
; <<>> DiG 9.16.22-Raspbian <<>> sigok.verteiltesysteme.net @127.0.0.1 -p 5335
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 56860
;sigok.verteiltesysteme.net. IN A
;; WHEN: Thu Dec 02 13:47:55 GMT 2021
;; MSG SIZE rcvd: 55
pi@raspberrypi:~ $
The post I've linked above recommends to alter a file and delete another and then restart unbound - but it does not recommend to remove nameservers individually?
Please read carefully through the linked post again.
ah Sorry i totally missed the link below!
Ive followed that, (commenting out the line and deleting the file, then restarting and now all seems to be working as expected!
now when i do a test at https://www.whatsmydnsserver.com/ it shows only my WAN address.
Many thanks for all your help!!
