*Iwhen apache2 is installed at machiene creation you will get this issue select the additional but apt your flaor of desktop cinnamon ssh additional buits and it worked di init install apache at all if installing pihole
[this is supposed to show the gui of the webpage]
[you try to load up pihole and you just get text only and php code if viewing from a windows pc]
this took be 2 hours to figure it out
install os and the extras
do not select apache and you will be fine
