Thanks jfb. Getting an error when trying to run pihole -up
pihole -up
/opt/pihole/update.sh: line 23: /etc/.pihole/automated install/basic-install.sh: No such file or directory
/opt/pihole/update.sh: line 99: : No such file or directory
/opt/pihole/update.sh: line 102: is_repo: command not found
Error: Core Pi-hole repo is missing from system!
Please re-run install script from https://pi-hole.net
Trying to rerun the installer to hopefully overwrite whatever is causing the issue also finishes with an error
[✓] Check for existing repository in /etc/.pihole
[i] Update repo in /etc/.pihole...
Error: Could not update local repository. Contact support.
Your best bet at this point might be to save your settings via teleporter, then uninstall and reinstall Pi-Hole from the curl script (curl -sSL https://install.pi-hole.net | bash), then move to release 4.0. We can do some troubleshooting, but it will likely be quicker on your part to reinstall.
Sounds like a project for when the wife is working late on Wednesday. Haven't done any customizing so not worried about having to get it up and running from scratch.
Had changed some things around over the weekend, and plugged my pi-hole into an underpowered USB port. That was fine for just having pi-hole running, but once I started trying to switch branches/reinstalling/troubleshooting, it never had enough power to complete things.
Put it into the right USB port, and all is right in the world.
Pi-hole Version vDev (release/v4.0, v3.3-428-g833131e) Web Interface Version v3.3 FTL Version vDev (release/v4.0, vDev-31d5fb9)
Got 4.0 up and running but have an error message appearing in settings.
There was a problem applying your settings.
Debugging information:
PHP error (2): syntax error, unexpected TC_LABEL, expecting '=' in /etc/pihole/pihole-FTL.conf on line 33 in /var/www/html/admin/settings.php:15
