Total manual install openSUSE aarch64
[Added repo, installed with zipper]
[rebooted and pi-hole status ok, how do I get the GUI/web to work please]
[Your debug token is: https://tricorder.pi-hole.net/fkxe51pq5g]
[✗] openSUSE Leap 15.1 (https://discourse.pi-hole.net/t/hardware-software-requirements/273)
This is not a supported operating system.
OK, I understand. Even if unsupported, where can I find some documentation to install it manually please and do my porridge on my own?
Cheers,
PS. I attempted this test because I saw this : https://docs.pi-hole.net/ftldns/compatibility/
I'd start looking within the community forums centered around the OS your are using :wink:
Also, if you can install Docker on your OS, you may be able to run Pi-hole from a Docker container, e.g. by adapting guides like this beginner-friendly one focussing on Portainer, Docker and Pi-hole.
If you'd decide to have Pi-hole as DNS and DHCP server (completely optional), be sure to consult Pi-hole's documentation on dockered DHCP for a few caveats.
Hiya,
I had no joy and that's why I came to you :slight_smile: I went the Docker way, it worked immediately! I have not delegated DHCP to pi-hole because the platform is sort of live with DHCP already running. This will be the last step.
I have built a block list and debugging FP (i.e. Facebook is KO).
Thanks for our help :slight_smile:
Hello,
Very interesting, thanks!
