I am running the following:
Pi-hole** [v5.2.4]
Web Interface** [v5.4]
FTL** [v5.7]
root@Pi-Hole:/home/pi# lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 10 (buster)
Release: 10
Codename: buster
root@Pi-Hole:/home/pi# hostnamectl
Static hostname: Pi-Hole
Icon name: computer
Machine ID: 1c2e9cd6c7b34718be04863f8aab563f
Boot ID: 471fadfb46f4441c9413a20a6b8b9e4d
Operating System: Raspbian GNU/Linux 10 (buster)
Kernel: Linux 5.10.11-v7l+
Architecture: arm
I have not experienced any functional issues with running Pi-Hole during the last two weeks. It is working flawlessly blocking sites to be expected and allowing access to sites that are to be expected. However in my recent review of the Top Lists found under the Long-term data, the "Top Blocked Domains" reflects some domains that are not in any block list or blacklist.
For example there are several domains I visit regularly without issue which are known good. I visit these sites often, every day. They are not being blocked, nor should they be, but for some unknown reason these domains are being listed in the "Top Blocked Domains" list.
The expected behavior (if not obvious) is that domains that are known to not be blacklisted or blocked, should not be appearing on the "Top Blocked List". Instead, only domains that are blocked or blacklisted should be appearing.
