Regarding the Tools->Network view.
Since I use IPv6 my hosts have many IP addresses.
However, Pi-Hole now/currently seems limited to showing only 3 addresses per host, as the hover over the 3 dots [...] is not showing the tooltip containing all known host IPs.
I remember that it worked in some older/previous version of Pi-Hole - just hover over the 3 dots and be presented with a mouse arrow tooltip that contained the full/long/all list of the hostnames and IPs.
Where did the tooltip go? Is this a bug or a feature? Back then I used Chrome, now I use Edge. But since both are Chromium, the browser cannot be the cause.
I checked using Chrome, Edge, and Firefox browsers (current versions as of today). All tested browsers result in the three-dot hover tooltip not showing up.
Edit: Not sure if this is relevant, but this is how it looks when I inspect the ... using browser's dev tools
Apparently this was broken 2 years ago, when the code was changed to avoid a few jquery warnings.
For my installation, it stopped working a "few" years ago as far as I can remember, so that correlates with "broken 2 years ago". I am looking forward to the fix in PiHole v6.
Could I fix the code myself or would that break something else?
Unrelated, but I thought I post it as confirmation for the working fix:
It really helps me correlate unresolved ipv6 hostnames to the hosts that are spamming the stats with a ton of IPv6 addresses. I think this is caused by Windows 11 IPv6 Temporary Addresses and similar shenanigans.
That led to me never knowing which of the "no host name" addresses belong to which host in the dashboard stats. Also, it led to one device filling the top 10 with 5 or more unresolved ipv6 hostname entries for the same device.
