Ton of 0.0.0.0.in-addr.arpa requests
I am enabled pi-hole dns and dhcp on my raspberry pi 4. I'm noticing a ton of arpa queries for 0.0.0.0.in-addr.arpa and 0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.ip6.arpa. I'm getting about 5/sec. It's filling up my logs and giving me a million queries per night. Is there any way to stop these? Thanks
What client is generating these requests? How are the requests being resolved by Pi-hole?
Here are 2 device examples. Each device is a smartthings hub that I'm using in bridge mode. Not sure why one device is getting a response while the other is being refused. Probably because I have IPV6 turned off at the router.
Mar 4 13:34:35 dnsmasq[32703]: query[PTR] 0.0.0.0.in-addr.arpa from 10.0.0.59
Mar 4 13:34:35 dnsmasq[32703]: config 0.0.0.0 is NXDOMAIN
Mar 4 13:34:35 dnsmasq[32703]: query[PTR] 0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.ip6.arpa from 10.0.0.59
Mar 4 13:34:35 dnsmasq[32703]: config :: is NXDOMAIN
Mar 4 13:34:35 dnsmasq[32703]: query[PTR] 0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.ip6.arpa from 10.0.0.72
Mar 4 13:34:35 dnsmasq[32703]: cached 0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.ip6.arpa is (null)
Mar 4 13:34:35 dnsmasq[32703]: config error is REFUSED
Mar 4 13:34:35 dnsmasq[32703]: query[PTR] 0.0.0.0.in-addr.arpa from 10.0.0.72
Mar 4 13:34:35 dnsmasq[32703]: cached 0.0.0.0.in-addr.arpa is (null)
Thanks!
Hard to answer without knowing your exact configuration. How are the two devices different? Does it always happen like this or was it rather a coincidence that .59 asked first and .72 second?
How does a SmartThings hub have a bridge mode? I have an older version without this. The hub just joins the network and uses the network connection to reach the Samsung servers.
The order is arbitrary. Just picked them out of the middle of the log file. The 2 devices are mesh network nodes called Smarthings Connect Hub made by Samsung. They create a mesh network with 1 SSID so you can extend your wifi throughout your house. I have a 3rd, but it's not plugged in.
The bridge mode is what's in the settings of the SmartThings app. I'm not bridging a wifi network though. it acts as it's own wifi router with it's own SSID.
Thanks!
You might want to check the Samsung forums for any information on this PTR request.
I have. Can't hurt to ask. Thx!
@eric859 I'd like to have a look at your exact configuration because this config line looks a bit suspicious and I'm unable to reproduce this locally, so far:
Tools > Generate Debug Log
I appreciate it, but I got rid of the offending mesh hubs. There was no support and you have very minimal configuration ability. Newer routers reach as far in my house as I need, so all it well. Thanks again.
