hello Pi-hole team apparently after the last update the time server stops working
sudo dpkg-reconfigure tzdata
sudo apt install ntp
service ntp status
service ntp status
This seems to be NTP-related.
How would you think Pi-hole is involved?
I'm not sure if it's a pihole problem, when at the time of installing sudo apt install ntp at the moment of showing the status I get an error
It isn't related to Pihole:
Your ntpd is telling you it is not allowed to run adj_systime.
This kind of message would occur e.g. if you were trying to run ntpd from some kind of virtualisation environment.
You should consider to also consult forums specialising in ntpd and/or your virtualisation software (if applicable).
Thanks @bucking_Horn I will investigate further
