I'm expecting to be able to access the web admin via my custom domain via traefik. (https://pihole.[server-name].lan) does not work, but 192.168.x.x:8053 (the port I have exposed in docker) does work. This is running as a docker-compose service, on Ubuntu 21.04. (Semi-related, the TEMPERATUREUNIT variable doesn't appear to change the actual temperature unit in the web ui, so maybe my environment variables aren't working properly?)
When trying to curl or reach my server in browser using my custom domain, I'm unable to reach the admin panel. I keep getting ERR_CONNECTION_TIMED_OUT.
I am able to reach other subdomains, so I know traefik is working.
My guess is I have to configure something differently with Traefik or the admin panel's nginx server is somehow not allowing me to access my website.
Here is what I have configured in my docker-compose file.
pihole:
depends_on: [unbound]
container_name: pihole
image: pihole/pihole:master-amd64-buster
ports:
- "53:53/tcp"
- "53:53/udp"
- "8053:80/tcp"
hostname: pihole
domainname: $SERVER_DOMAIN
dns:
- 127.0.0.1
- $UNBOUND_IP_ADDRESS
environment:
TZ: $TZ
PIHOLE_DNS_: $UNBOUND_IP_ADDRESS
ServerIP: $SERVER_IP_ADDRESS
PROXY_LOCATION: pihole
VIRTUAL_HOST: pihole.$SERVER_DOMAIN
WEBPASSWORD: "password"
PIHOLE_DOMAIN: $SERVER_DOMAIN
TEMPERATUREUNIT: "f"
volumes:
- "./services/pihole/:/etc/pihole/"
- "./config/dnsmasq/:/etc/dnsmasq.d/"
cap_add:
- NET_ADMIN
restart: unless-stopped
labels:
- "traefik.enable=true"
networks:
traefik:
vpn:
ipv4_address: $PIHOLE_IP_ADDRESS
Here is my Traefik config:
http:
routers:
pihole:
entryPoints:
- https
rule: Host(`pihole.{{env "SERVER_DOMAIN"}}`)
service: pihole-svc
middlewares: admin-prefix
tls: {}
services:
pihole-svc:
loadBalancer:
servers:
- url: "http://{{env `SERVER_IP_ADDRESS`}}:8053/"
middlewares:
admin-prefix:
addPrefix:
prefix: "/admin/"
I also "whitelisted" the SERVER_DOMAIN value, and it still just loads forever.
