There seems to be a loop resolving FQDN in LAN
The issue I am facing:
Ever since I've set a domain name on my router, I've noticed some strange activities.
Where once I usually get 200 queries per hour, it has now jumped to 2000 queries per hour.
pihole.log is full of the following records:
Mar 19 18:10:09 dnsmasq[3608298]: query[AAAA] localhost.local.home from 192.168.70.1
Mar 19 18:10:09 dnsmasq[3608298]: forwarded localhost.local.home to 192.168.70.1
Mar 19 18:10:09 dnsmasq[3608298]: cached localhost.local.home is (null)
As a consequence of this it has probably also led to this issue (which I've also raised):
Apart from the surge in number of queries, throwing off graph and historical data, and the the issue I've detailed above (#45481) pihole is working as expected.
And so while this issue is not critical, there is something not quite right.
Let me know if I'm doing something wrong or if there's a switch I should set. Thanks
Details about my system:
Router (192.168.70.1):
  • Custom Rom (FreshTomato router)
  • Provides DHCP
  • Hostname: router
  • Domain name: local.home
  • Forwards all DNS queries to Pihole
Environment:
  • Pihole OS: Ubuntu 20.04.2
  • Pihole: v5.2.4
  • Pihole web: v5.4
  • FTL: v5.7
  • Interface listening behavior: Listen on all interfaces, permit all origins
  • Never forward non-FQDNs: On
  • Use Conditional Forwarding: On
  • DNSSEC: Off
Conditional Forwarding setup:
  • LAN: 192.168.70.0/24
  • DHCP: 192.168.70.1
  • Local Domain: local.home
Conditional forwarding appears to be causing this loop.
Correct. Turning off Conditional Forwarding has resolved this issue, as I discovered in the linked issue.
