Theme Changed?
Hello!
I was using pihole and saw there was an update, updated to the latest version and everything is fine but I am pretty sure the ui theme has changed. I don't remember changing any settings. I personally like the old theme much better but I didn't see any changes about the themes in the changelog. I was wondering if the theme actually changed of if something else is causing it. I have only noticed the theme change in the Query Log page if that matters.
Thanks!
Yes. See here
Is there a way to go back to the previous version? If not could you add a new theme option in settings? (if there isn't a way to go back that's fine too)
https://github.com/pi-hole/AdminLTE/pull/1893
Ok, so its going to have more color.
