The SQL database is corrupted due to being in operation for more than a day.
Replace this text with what you think should be happening. Please include as much detail relevant to your system/install as possible including, but not limited to:
  • Rasberry Pi OS x64 (Debian Trixie)
  • Rasberry Pi 4, B, 8 GB of RAM
  • None
  • None
I have error an error about SQL. Out of curiosity, I decided to look at the list of clients connected to this device. A message popped up in the web interface: "An unknown error occurred while loading the data.
{"error":{"key":"not_found","message":"Not found","hint":"/api/network/devices"},"took":0.0026574134826660156}". I decided to check the logs using the web client's built-in utility: Tools -> Tail Log Files -> FTL.log. I tried deleting the database and trying to fix it:
  • sudo service pihole-FTL stop
  • sudo mv /etc/pihole/pihole-FTL.db /etc/pihole/pihole-FTL-old.db
  • sudo service pihole-FTL start
, but nothing worked.
https://tricorder.pi-hole.net/0sIMGa1p/
