At 07:20, the electricity goes off and the graph shows that no queries were made after this time.
But I don't see ads on the sites I visit
When I use the "sudo service pihole-FTL restart" command , the graphic starts recording again.
Then the same problem repeats when the power is cut off. Help me. Thanks
If I watch closely, I can see some queries received during the time you circled.
The issue is likely the following:
WARN: Could not sendto() in send_dhcp_discover() (/__w/FTL/FTL/src/dhcp-discover.c:233): Network is unreachable
* Received 548 bytes from eth0:192.168.1.1
Offered IP address: 192.168.1.7
Server IP address: N/A
Relay-agent IP address: N/A
BOOTP server: (empty)
BOOTP file: (empty)
DHCP options:
Message type: DHCPOFFER (2)
lease-time: Infinite
netmask: 255.255.255.0
router: 192.168.1.1
dns-server: 192.168.1.7
dns-server: 192.168.1.1
--- end of options ---
You advertise Pi-hole's and your router's IP as DNS servers via DHCP. After the power-loss, your network clients renewed their DHCP lease and picked your router as upstream DNS server.
You should not set any DNS server next to Pi-hole as your clients will start using the other DNS server whenever they want. Only advertise Pi-hole's IP.
