Requesting the IP for craft.test should have the request passed to the upstream resolve and an answer returned.
I'm using Bind as an upstream resolver for a bunch of internal domains, two relevant ones .krynn.int and .test.
Everything is working fine if I request an IP for blah.krynn.int, Pi-hole passes up the request and I get an IP.
If I request something on .test, say craft.test I don't get an answer. From the log file I see:
Nov 30 12:02:05 dnsmasq[5069]: query[A] craft.test from 192.168.0.7
Nov 30 12:02:05 dnsmasq[5069]: config craft.test is NXDOMAIN
The subdomain does exist on the upstream DNS:
# dig @localhost -p 5353 craft.test
; <<>> DiG 9.16.33-Debian <<>> @localhost -p 5353 craft.test
; (2 servers found)
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 21345
; COOKIE: 04ce162fae7e844701000000638747887161ae668a912df0 (good)
;craft.test. IN A
craft.test. 300 IN A 192.168.0.52
;; Query time: 0 msec
;; SERVER: ::1#5353(::1)
;; WHEN: Wed Nov 30 12:07:36 GMT 2022
;; MSG SIZE rcvd: 83
I have Never forward non-FQDN A and AAAA queries turned off and have stopped and restarted the service.
I've checked it is in the config file:
BLOCKING_ENABLED=true
CONDITIONAL_FORWARDING=false
DNSMASQ_LISTENING=single
DNS_FQDN_REQUIRED=false
DNS_BOGUS_PRIV=true
DNSSEC=false
REV_SERVER=false
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.0.8/24
IPV6_ADDRESS=
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
CACHE_SIZE=10000
PIHOLE_DNS_1=192.168.0.8#5353
This was working before I upgraded to the latest version:
Pi-hole v5.14.2 FTL v5.19.2 Web Interface v5.17
What has changed and what do I need to change back to get it working again?
I'll upload data from the debug log if required.
