Teleporter export should export the configuration file
No exportable configuration file is created. Nothing appears to happen when the export button is pressed. I have tried 2 browsers. The FTL.log shows
ERROR Failed to validate generated Teleporter ZIP archive: validation failed
WARNING API: Failed to validate generated Teleporter ZIP archive
It means ... well ... that miniz thinks the archive it just created isn't valid. Please try
pihole checkout ftl fix/teleporter_zip_verify
and see how this behaves. The inability to verify the archive will only be a warning to the log here, you can get the file nonetheless. Does it appear like a regular ZIP file? Could you somehow (privately) sent it to us for verification (e.g. via direct message here on Discourse)?
Hi DL6ER. I ran pihole checkout ftl fix/teleporter_zip_verify (it needed a sudo on the front) and this time a file was created (beforehand no file appeared to be created). It looks like a valid zip archive. Well done and thankyou.
Jeff
Thanks for sending the file. I can confirm it is valid,
$ unzip -t pi-hole_raspberrypi_teleporter_2025-02-19_06-49-28_CST.zip
Archive: pi-hole_raspberrypi_teleporter_2025-02-19_06-49-28_CST.zip
testing: etc/pihole/pihole.toml OK
testing: etc/hosts OK
testing: etc/pihole/dhcp.leases OK
testing: etc/dnsmasq.d/backup OK
testing: etc/pihole/gravity.db OK
testing: etc/pihole/pihole-FTL.db OK
No errors detected in compressed data of pi-hole_raspberrypi_teleporter_2025-02-19_06-49-28_CST.zip.
