I have Pihole installed using diet-pi as the base OS. This is all installed on a intel based HP thin client.
I have configured pihole to be my DHCP server (192.168.1.2), and turned off the router DHCP (192.168.1.1)
My Tado gateway should be assigned a reserved address from the DHCP pool:
Mac address:- EC-E5-12-1F-##-## (redacted for security) - against IP address 192.168.1.120
IP address does not get assigned, all other reservations are assigned correctly.
Looking at the logs the device is discovered, then offered an IP address repeatedly.
https://tricorder.pi-hole.net/TlaDsRvC/
Thanks in advance.
