Hello, my settings tab stopped showing the network info tab like it did before I installed the beta (web 5.6 and all). Not a very big issue but I thought it was worth mentioning.
You mean Tools/Network?
This is intentional. The data shown here was sourced from a static config file and may not have been true at all.
How okay, well thanks for the quick answer then.
No in the settings/system tabs but DL6ER solved it.
