Is there any data available providing a consensus view as to what Synology RT2600AC settings yield the optimal performance across a router/pi-hole combination? A thorough assessment would need several controlled experiments, I'm trying to avoid duplicating what may already exist.
From reading many posts on many sites and trying various experiments there are a multiplicity of configuration options, each of which gives different results and underlying data. I have summarised these below.
For my application, I have no specific need to see which device is contributing to the queries, I just want to ensure the most effective solution. (I did experiment with Conditional Forwarding but I found that in some configurations it just produced so many queries from reverse IP lookups - xxx.yyy.zzz.192.in-addr.arpa - that it didn't really add value under those conditions.)
The network is set up with every device given a DHCP reservation as that's my preference for managing the devices. I'm also avoiding using the pihole to manage DHCP, keeping that in the router.
Any thoughts or suggestions from other experiences?
