Hey All,
I want to setup DOH & DOT with Pihole & Unbuond.
Does anyone have a guide or script with best practices that runs you through this process?
DC
Hey All,
DC
Using both next to each other doesn't make sense.
You should opt for either DoH or DoT.
What's the intended use case?
I wanted to increase security and add my pihole dns server to my android phone. Android Private DNS supports both apparently.
Do you have a suggestion for one over the other?
I have both unbound and DoH using dnscryp-proxy compliment of the Pi-hole team here Issue installing dnscrypt-proxy - Help - Pi-hole Userspace
That sounds as if you would want your Android phone to use DoH/DoT to connect to your Pi-hole?
Yes that's right.
(Smurf's post won't help you here, as that is about Pi-hole forwarding to a DoT/DoH proxy that takes plain DNS requests from Pi-hole to encrypt and forward them to public DoT/DoH servers.)
You would need a DoT or DoH server in front of Pi-hole in that case, accepting and decrypting DoT/DoH requests and forward plain DNS to P-hole.
But that won't offer much of a benefit in your home network.
Do you intend to access Pi-hole remotely, connecting via public Internet?
Yes.
I plan on accessing this pihole server over the internet using tailscale to keep in private.
I'd go for something like dnsdist as a front end to provide you with DoT when you are away from your LAN connection.
There are other options like stubby or even nginx but I like dnsdist personally.
If you are using tailscale, you are already using an encrypted connection into your home network, so again not much benefit from installing DoT/DoH in front of Pi-hole.
Do you have a guide for a great config for DNSDist?
Yeah but I have to have one or the other for android. It no longer lets you use DNS that is not either DOH or DOT.
As far as I am aware of, Android's Private DNS feature is employing DoT exclusively.
What Android version are you using?
I'm using Android 15.
DNSDist looks like a good option. What do you think Bucking_Horn?
Since you are using tailscale already, I'd leave Android's Private DNS feature on automatic (or off, if automatic would fail to determine that your current network propagate's Pi-hole for DNS and DoT shouldn't be used).
OK Thanks.
Tailscale already handles the encryption for you, setting up DoH/DoT over a vpn is redundant, ie. you are already secured through tailscale.
Thanks.
