Status is showing as active but suddenly stopped blocking ads two days ago. I reinstalled but still not blocking ads. Status shows as active.
The log shows Pi-hole is able to block domains.
It also shows:
- the Pi has 2 IPs:
192.168.5.89
(wlan0) and192.168.5.84
(eth0); - your router is advertising itself as DNS server (
192.168.4.1
How did you configured your devices to use Pi-hole?
THANK YOU!
I didn't realize I had a separate eth0 IP and had mistakenly added the wlan0 IP to my router's IPv4 reservation.
Fixed and it now works again.
