Stucked in [i] Cleaning up stray matter
Hi. I did an upgrade to Beta 6.0 and the verbose screen is stucked in this phase:
  [✓] Supported OS detected
  [i] Update option selected
  [✓] Check for existing repository in /etc/.pihole
  [i] Update repo in /etc/.pihole...HEAD está ahora en 2d81552f Pi-hole core v6.0.0 (#5842)
  [✓] Update repo in /etc/.pihole
  [✓] Check for existing repository in /var/www/html/admin
  [i] Update repo in /var/www/html/admin...HEAD está ahora en a66d859a Pi-hole web v6.0.0 (#3190)
  [✓] Update repo in /var/www/html/admin
  [i] FTL Checks...
  [✓] Detected ARMv6 architecture
  [✓] Downloading and Installing FTL
  [✓] Installing scripts from /etc/.pihole
  [✓] Installing latest Cron script
  [i] Installing latest logrotate script...
	[i] Old log file paths updated in existing logrotate file.
	[i] webserver.log added to logrotate file.
  [✓] Installing latest logrotate script
  [✓] man pages installed and database updated
  [✓] Stopping lighttpd service...
  [✓] Disabling lighttpd service...
  [✓] Migrating Pi-hole configuration to version 6
    Migrating config to Pi-hole v6.0 format
    Reading legacy config files from /etc/pihole/pihole-FTL.conf
       PIDFILE: Empty path is not possible, using default
       SETUPVARSFILE: Empty path is not possible, using default
       MACVENDORDB: Empty path is not possible, using default
       GRAVITYDB: Empty path is not possible, using default
       WEBROOT: Empty path is not possible, using default
       WEBHOME: Empty path is not possible, using default
       API_INFO_LOG: Empty path is not possible, using default
       WEBDOMAIN: Empty path is not possible, using default
    Moving /etc/pihole/pihole-FTL.conf to /etc/pihole/migration_backup_v6/pihole-FTL.conf
    Migrating config from /etc/pihole/setupVars.conf
    setupVars.conf:WEBPASSWORD -> Setting webserver.api.pwhash to 580d672c1fae5e6ed1496f8e659df933524316d7061fccc4503ab489984cad5f
    setupVars.conf:BLOCKING_ENABLED -> Setting dns.blocking.active to true
    setupVars.conf:TEMPERATURE_LIMIT -> Not set
    setupVars.conf:TEMPERATURE_UNIT -> Not set
    setupVars.conf:WEBUIBOXEDLAYOUT -> Not set
    setupVars.conf:WEBTHEME -> Not set
    setupVars.conf:PIHOLE_DNS_1 -> Setting dns.upstreams[1] = 8.8.8.8
    setupVars.conf:PIHOLE_DNS_2 -> Setting dns.upstreams[2] = 8.8.4.4
    setupVars.conf:PIHOLE_DOMAIN -> Not set
    setupVars.conf:DNS_FQDN_REQUIRED -> Setting dns.domainNeeded to true
    setupVars.conf:DNS_FQDN_REQUIRED -> Setting dns.expandHosts to true
    setupVars.conf:DNS_bogusPriv -> Not set
    setupVars.conf:DNSSEC -> Setting dns.dnssec to false
    setupVars.conf:PIHOLE_INTERFACE -> Setting dns.interface to eth0
    setupVars.conf:HOSTRECORD -> Not set
    setupVars.conf:DNSMASQ_LISTENING -> Setting dns.listeningMode to LOCAL
    setupVars.conf:REV_SERVER_CIDR -> Not set
    setupVars.conf:REV_SERVER_TARGET -> Not set
    setupVars.conf:REV_SERVER_DOMAIN -> Not set
    setupVars.conf:REV_SERVER_* -> Not set (found invalid/incomplete parameters)
    setupVars.conf:DHCP_ACTIVE -> Not set
    setupVars.conf:DHCP_START -> Not set
    setupVars.conf:DHCP_END -> Not set
    setupVars.conf:DHCP_ROUTER -> Not set
    setupVars.conf:DHCP_LEASETIME -> Not set
    setupVars.conf:DHCP_IPv6 -> Not set
    setupVars.conf:DHCP_RAPID_COMMIT -> Not set
    setupVars.conf:queryLogging -> Not set
    setupVars.conf:GRAVITY_TMPDIR -> Not set
    setupVars.conf:WEB_PORTS -> Not set
    Moved /etc/pihole/setupVars.conf to /etc/pihole/migration_backup_v6/setupVars.conf
    setupVars.conf migration complete
    Moving /etc/pihole/custom.list to /etc/pihole/migration_backup_v6/custom.list
    Config initialized with webserver ports 8080 (HTTP) and 443 (HTTPS), IPv6 support is enabled
    Wrote config file:
     - 152 total entries
     - 145 entries are default
     - 7 entries are modified
     - 0 entries are forced through environment
    Config file written to /etc/pihole/pihole.toml
  [i] Testing if systemd-resolved is enabled
  [i] Systemd-resolved is not enabled
  [i] Upgrading gravity database from version 15 to 16
  [i] Upgrading gravity database from version 16 to 17
  [i] Upgrading gravity database from version 17 to 18
  [i] Upgrading gravity database from version 18 to 19
  [i] Restarting services...
  [✓] Enabling pihole-FTL service to start on reboot...
  [✓] Restarting pihole-FTL service...
  [✓] Migrating the list's cache directory to new location
  [✓] Deleting existing list cache
  [✓] DNS resolution is available
  [✓] Creating new gravity databases
  [i] Using libz compression
  [i] List has been updated
  [✓] Parsed 125376 exact domains and 0 ABP-style domains (blocking, ignored 0 non-domain entries)
  [✓] Building tree
  [i] Number of gravity domains: 125376 (125376 unique domains)
  [i] Number of exact denied domains: 0
  [i] Number of regex denied filters: 0
  [i] Number of exact allowed domains: 1
  [i] Number of regex allowed filters: 0
  [✓] Optimizing database
  [✓] Swapping databases
  [✓] The old database remains available
  [i] Cleaning up stray matter...
^C
  [i] User-abort detected
^[[A
^C
Any ideas?
Rebooted. Solved. tHANKS!
