I have a problem with pihole status bar.
I just install pihole in my pogoplug E02.
When I install pihole everything work fine except status unknown issue.
I tried to click the enable button, and the status looks like changed unknown to active.
But it will be changing after I click any of the main navigation.
Also when I click Disable, and check pihole status.
Pihole still running, it is not disable by web interface.
It only can be disable by terminal.
Please help me to fix it.
I already reinstall the pihole, but still have same issue.
I did compile the pihole-ftl at the first installation. But I didnt install the pihole-FTL at the second installation. However, it still not working an status bar.
That's the output of the command when run as root. Pi-hole runs with a non-root user and I seem to remember that changing the user and calling systemctl or service inside the chroot jail that you have to create to get Debian running on a Pogo is not compatible.
I still don't quite understand what you did to install Pi-hole. Did you compile and copy the binary and then run some other command? Or did you run some other command (curl?) first and then compile the binary?
You need to be very specific with the exact commands and steps you used since this really isn't a supported platform for Pi-hole.
Oh! Yes, I'm already installed curl for pihole.
I also hack the pogo and it doesn't have original ui any more.
I will try to installing the pihole with non-root user.
