Status offline on Centos 7, pihole works
The issue I am facing:
on the web i/f status always says: 'Offline' - though pihole works as expected
if I disable via admin page, then enable, says 'Active', when page refreshes, says again 'Offline'
looking on this forum, found similar issue, with such solution:
ls -l /usr/bin/sudo
---s--x--x. 1 root root 151424 Oct 14 23:28 /usr/bin/sudo
did below line, result below
sudo chmod 4755 /usr/bin/sudo
ls -l /usr/bin/sudo
-rwsr-xr-x. 1 root root 151424 Oct 14 23:28 /usr/bin/sudo
but, didn't help
Details about my system:
Centos 7, Apache
pihole status
[✓] FTL is listening on port 53
[✓] UDP (IPv4)
[✓] TCP (IPv4)
[✓] UDP (IPv6)
[✓] TCP (IPv6)
pihole version
Pi-hole version is v5.8.1 (Latest: v5.8.1)
AdminLTE version is v5.10.1 (Latest: v5.10.1)
FTL version is v5.13 (Latest: v5.13)
error_log has:
[Sun Jan 23 10:50:30.975554 2022] [php7:warn] [pid 1506] [client 192.168.1.28:55140]
PHP Warning: Executing sudo pihole status web failed. in
/var/www/html/admin/scripts/pi-hole/php/func.php on line 150, referer:
http://192.168.1.8/admin/index.php?login
[Sun Jan 23 10:50:30.975662 2022] [php7:notice] [pid 1506] [client
192.168.1.28:55140] PHP Notice: Undefined variable: temperaturelimit in
/var/www/html/admin/scripts/pi-hole/php/header.php on line 379, referer:
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
sudo: no tty present and no askpass program specified
[Sun Jan 23 10:54:32.243870 2022] [php7:warn] [pid 23573] [client
192.168.1.28:63654] PHP Warning: Executing sudo pihole disable failed. in
[Sun Jan 23 10:54:36.474311 2022] [php7:warn] [pid 1486] [client 192.168.1.28:63670]
PHP Warning: Executing sudo pihole enable failed. in
[Sun Jan 23 10:54:42.761389 2022] [php7:warn] [pid 19274] [client
192.168.1.28:63668] PHP Warning: Executing sudo pihole status web failed. in
[Sun Jan 23 10:54:42.761470 2022] [php7:notice] [pid 19274] [client
192.168.1.28:63668] PHP Notice: Undefined variable: temperaturelimit in
what am I doing wrong ?
(also, temperature doesn't work)
Please generate a debug log, upload it when prompted and post the token URL here.
pihole -d -a
[✓] Your debug token is: https://tricorder.pi-hole.net/8vl49yVF/
I think the problem is related to running an unsupported web server.
HTTP/1.1 200 OK
Date: Sun, 23 Jan 2022 01:43:01 GMT
Server: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips mod_fcgid/2.3.9 mod_wsgi/3.4 Python/2.7.5 PHP/7.3.33
X-Powered-By: PHP/7.3.33
Content-Type: text/html; charset=UTF-8
What device are you running Pi-hole on? We only check in two places for temp sensors (there are many!) and due to a bug the above error message gets printed. This has been fixed in the next release (the error message, not the temp sensor lookup).
_
What is the output of
thanks! it's an old HP SFF PC:
Architecture:          x86_64
CPU op-mode(s):        32-bit, 64-bit
Model name:            Intel(R) Core(TM)2 Duo CPU     E6550  @ 2.33GHz
Stepping:              11
CPU MHz:               1998.000
CPU max MHz:           2333.0000
CPU min MHz:           1998.0000
BogoMIPS:              4654.96
# sudo pihole status web
53
I do have lmsensors if that can be adapted ?
# sensors
coretemp-isa-0000
Adapter: ISA adapter
Core 0:       +37.0°C  (high = +78.0°C, crit = +100.0°C)
Core 1:       +35.0°C  (high = +78.0°C, crit = +100.0°C)
smsc47b397-isa-0480
fan1:        1789 RPM
fan2:           0 RPM
fan3:        1253 RPM
fan4:        1005 RPM
temp1:        +53.0°C
temp2:        +43.0°C
temp3:        +25.0°C
temp4:       -128.0°C
The reply is correct, so it is likely an permission issue with your apache.
We do look for sensors in
You might want to support
