gtrnz
1
[Static IP to be removed when using the red trash button to the right]
[Static IP remained in DHCP reservations list]
[u3i2vbr7bv]
RamSet
2
There is probably something related to your cache and cookies. You can try a different browser (or even go in incognito or private mode).
There's always the option of manually editing the /etc/dnsmasq.d/04-pihole-static-dhcp.conf
Try deleting the IP in the interface and then check to see if it's still present in this file.
Or the other way around. Delete from the file and check the interface.
system
Closed
3
