Startup not working
website displayed
can't connect to anything
z72vdzdwvk
A few problems noted in your debug log:
The Pi has no IP address on the network.
[✗] No IPv4 address(es) found on the eth0 interface.
The Pi can't connect to the gateway (router):
   * Pinging 192.168.1.1...
Because of that, your gravity list is empty. That will be rebuilt when you repair your installation.
Check that the Pi has a connection on the network, then run pihole -r and select repair option. If pihole -r fails, there are additional steps you can take.
it is connected via wireless and pings the gateway fine.
Internet also works on Pi
i see it says eth0, but when I set it up I think I selected wireless. I will try to fix that or reinstall.
I can't find a place to change that. do I need to reinstall?
OK thx I found it and I guess the 3rd try at install I forgot to chg the adapter used.
pihole -r and select "reconfigure" will do it.
