Standard Pi-Hole install + LE SSL + Apache virtualhost
The issue I am facing:
Hi there,
I'm trying to set up Pi-Hole as a subdomain of my existing Apache installation on my Raspberry Pi. All my current Apache configurations use my existing Let's Encrypt certificates (*.domain.com & domain.com), so I only have to update 2 certificates for all my services.
I started by forwarding the lighttpd port to :4567 to use ProxyPass on my VirtualHost.
I then try to modify the external.conf file of lighttpd to allow SSL by following the tutorial in this forum. However, I only get errors because my port :443 "is already in use", but more importantly, when my configuration doesn't produce errors when restarting lighttpd, I get an error 500 "Error during SSL Handshake with remote server".
What am I doing wrong?
My configuration:
# /etc/apache2/sites-enabled/000-default.conf
<VirtualHost *:80>
	ServerName pihole.domain.com
	RewriteEngine on
	RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
# /etc/apache2/sites-enabled/000-default-le-ssl.conf
<VirtualHost *:443>
	Timeout 5400
	ProxyTimeout 5400
	SSLProxyEngine On
	SSLProxyVerify None
	SSLProxyCheckPeerCN Off
	SSLProxyCheckPeerName Off
	SSLProxyCheckPeerExpire Off
	ProxyPass / https://localhost:4567/admin/
	ProxyPassReverse / https://localhost:4567/admin/
	ErrorLog ${APACHE_LOG_DIR}/error.log
	CustomLog ${APACHE_LOG_DIR}/access.log combined
	# Let's Encrypt
	SSLCertificateFile /etc/letsencrypt/live/domain.com/fullchain.pem
	SSLCertificateKeyFile /etc/letsencrypt/live/domain.com/privkey.pem
	Include /etc/letsencrypt/options-ssl-apache.conf
</VirtualHost>
# /etc/lighttpd/external.conf (lighttpd.conf is unmodified)
server.port := 4567
server.modules += (
  "mod_openssl"
# Beginning of problems
# temporary
$HTTP["host"] != "pihole.domain.com" {
  url.redirect = ("" => "https://pihole.domain.com")
# Modified configuration from tutorial
#$HTTP["host"] == "pihole.domain.com" {
  # Ensure the Pi-hole Block Page knows that this is not a blocked domain
  setenv.add-environment = ("fqdn" => "true")
  # Enable the SSL engine with a LE cert, only for this specific host
  #$SERVER["socket"] == ":443" { # if I leave this, "443 already used", else "ssl.engine is valid only in global scope or $SERVER["socket"]
    ssl.engine = "enable"
    ssl.pemfile = "/etc/letsencrypt/live/domain.com/combined.pem" # combined as tutorial did
    ssl.ca-file =  "/etc/letsencrypt/live/domain.com/fullchain.pem"
    ssl.cipher-list = "EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH"
  # Redirect HTTP to HTTPS ➜ not needed as my Apache VirtualHost already handles this
  #$HTTP["scheme"] == "http" {
  #  $HTTP["host"] =~ ".*" {
  #    url.redirect = (".*" => "https://%0$0")
Details about my system: Raspberry Pi 3, latest version, lighttpd-mod-openssl installed
What I have changed since installing Pi-hole: Nothing but DNS servers and these files
Thanks!
(N.B.: Note that most of the ssl keys given by the tutorial are deprecated, a working configuration with updated keys would be amazing)
Try http://localhost:4567/admin/ instead of https
Tried changing only that AND commenting # temporary part in external.conf, nothing changed
deHakkelaar can you help me or mention someone that could, please?
I think what goes wrong with your setup is trying to proxy https to https which could pose a security risk and fails because of how SSL/TLS works ... not sure though.
I would first default that external.conf file again so lighttpd listens default to port 80 without SSL/TLS.
If port 80 conflicts with other services, configure lighttpd to listen on that other port 4567 that you mentioned (but without SSL).
Then proxy port 80 on apache to port 80 (or 4567) for lighttpd.
If that works, try proxy port 443 (with SSL) on apache to port 80 (without SSL) from lighttpd.
I've got a similar setup where the proxy target 192.168.0.4:8080 is without SSL:
<VirtualHost *:443>
    ProxyPreserveHost On
    ProxyPass / http://192.168.0.4:8080/
    ProxyPassReverse / http://192.168.0.4:8080/
EDIT: I have no experience with that SSLProxyEngine directive.
Maybe that one does allows you to proxy https to https somehow.
EDIT2: What also is unclear to me, are apache and lighttpd running on the same host?
If so, why not entirely switch to apache and ditch lighttpd?
That would make the cert renewal easier and you only have one cert instead of two.
Thank you for your answer. What you're describing seems great, I'm gonna try it right now.
About edit 1: AFAIK it's something to handle SSL correctly, and I even think it's required for it
About edit 2: Yes, they are (I even have another service provided with nginx, I have my apache redirecting to it too). I would love to move entirely to apache, but I'm not sure how to configure my virtualhost to replicate the exact same configuration as lighttpd.
But I've had found someone who migrated this way and who disables lighttpd again after each pi-hole update, but they haven't shared their exact configuration I'm looking for. So... redirect for now.
It worked thank you!!
Final configuration:
# /etc/apache2/sites-enabled/000-default.conf (unchanged)
<VirtualHost *:80>
	RewriteEngine on
</VirtualHost>
<VirtualHost *:443>
        # non mandatory lines
	Timeout 5400
	ProxyTimeout 5400
	SSLProxyEngine On
	SSLProxyVerify None
        # end of non mandatory lines
	ProxyPass / http://localhost:4567/admin/ # notice 'http' and not 'https'
	ProxyPassReverse / http://localhost:4567/admin/ # same
	ErrorLog ${APACHE_LOG_DIR}/error.log # both non mandatory neither
	# Let's Encrypt
	SSLCertificateFile /etc/letsencrypt/live/pihole.domain.com/fullchain.pem
	SSLCertificateKeyFile /etc/letsencrypt/live/pihole.domain.com/privkey.pem
</VirtualHost>
server.port := 4567 # whatever you want, just make it match with apache's virtualhost
setenv.add-environment = ( "VIRTUAL_HOST" => "pihole.domain.com" ) # very important!
That's it! Then a good old
sudo apache2ctl restart; sudo systemctl restart lighttpd
...and here you go!
Thanks again @deHakkelaar!
Dont need to do that.
During install, you were asked two questions:
  1. Install web server (lighttpd);
  2. Install web files/interface (in /var/www/html/).
These are stored in below file:
pi@ph5b:~ $ cat /etc/pihole/setupVars.conf
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
So setting INSTALL_WEB_SERVER=false, makes sure that Pi-hole wont install lighttpd + PHP dependencies.
But keeping INSTALL_WEB_INTERFACE=true, makes sure the web files are installed in that /var/www/html/admin/ folder that can be used as a DocumentRoot for a VirtualHost in apache2.
Below the PHP web dependencies that are also needed for apache2:
pi@ph5b:~ $ curl -sSL install.pi-hole.net | grep -i deps
        PIHOLE_WEB_DEPS=(lighttpd lighttpd-fastcgi php-common php-cli php-pdo php-xml php-json php-intl)
And the www-data user, under which apache2 runs, needs to be a member of the pihole group to be able to write to certain locations.
With below you can check
pi@ph5b:~ $ groups www-data
www-data : www-data pihole
And below can be used if you want to add the www-data user to the pihole group:
sudo usermod -a -G pihole www-data
Thanks for the info. Won't do cause it's working well like that but if anyone else needs it or if someday I wanna change, thanks
