SSO Option
Continuing the discussion from 2FA for the Admin page:
@DL6ER I'm curious what happened to this idea. I was thinking about mucking around in the code in a homebrew to see what an SSO implementation would look like...
I would love to see an SSO option. I'd personally give a vote to have Apple has an option.
I see the option to add 2FA on v6, but whenever I add it, the password breaks completely and I have to remove the password (leave it blank) and disable 2FA to put a password back on. I do not see the added box for the OTP password on the pihole login screen once it is enabled.
Yes, it is definitely broken. I've added an issue.
https://github.com/pi-hole/web/issues/2779
