SSO OIDC Integration
Following a lot of other apps, are there/or have there been yet any plans to create any sort integration for pihole to allow OIDC login?
I imagine, this could be either a full integration or just some sort of middleware that skips the internal login screen and uses the oidc provider just to check if the user is authenticated.
Generally it’s a nice system which simplifies login through the band of selfhosted things.
Thanks!
