SSL_ERROR_RX_RECORD_TOO_LONG
Going to https://pi.hole/admin should open my pi-hole WebUI from any device on my network.
WebUI is accessible from my phone and laptop, but not on my PC. Phone is Android, laptop is Windows, PC is Linux Mint.
This was not an issue until the most recent update. Not sure what changed, I haven't changed any settings since then, it just doesn't work from Linux anymore.
https://tricorder.pi-hole.net/UqW62rBe/
The error ssl_error_rx_record_too_long issue only occurs in Mozilla Firefox. Even if other browsers could have variations of the issue, you probably won’t encounter it when using them. For instance, it states that the website you are attempting to visit is unavailable **“**because the authenticity of the received data could not be verified.” In a nutshell, the SSL certificate’s improper configuration is the most typical issue, which prevents your browser from successfully establishing a connection with the server’s port. There are many different ways to fix the error, such as:-
  1. Clear your browser history and Cache
  2. Change your TLS preference
  3. Use HTTP Protocol
  4. Update the proxy settings
