Ssh: connect to host 192.168.1.xyz port 22: Connection refused
I wish to log in via command line.
I used to be able to log in, but the connection is refused now. The Pi Hole is working fine, and I can log into the web admin portal. But no command line, and so I'm not sure how I can update the Pi going forward.
https://tricorder.pi-hole.net/SvMwczla/
That is a network/OS level issue, not related to Pi-hole nor DNS.
Perhaps ssh wasn't configured correctly, or your firewall on the device is not allowing inbound port 22.
You'd have to consult your OS's documentation for further details.
