Probably unrelated to your issue:
Why would you do so when your debug log shows that both interfaces are on the same subnet?
*** [ DIAGNOSING ]: Network interfaces and addresses
inet 192.168.0.200/24 brd 192.168.0.255 scope global noprefixroute eth0
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
inet 192.168.0.199/24 brd 192.168.0.255 scope global noprefixroute wlan0
As your RPi is accessible via a wired eth0
interface, that should be your preferred connection.
You may as well turn off your RPi's wlan0
interface completely and spare your network from some routing decisions and save some power as well.
You'd have to run pihole -r
with Reconfigure if you'd have currently tied your Pi-hole to wlan0
instead of eth0
Also, your debug log shows you are using as much as fourteen different upstream DNS servers:
PIHOLE_DNS_1=8.8.8.8
PIHOLE_DNS_2=8.8.4.4
PIHOLE_DNS_3=2001:4860:4860:0:0:0:0:8888
PIHOLE_DNS_4=2001:4860:4860:0:0:0:0:8844
PIHOLE_DNS_5=208.67.222.222
PIHOLE_DNS_6=208.67.220.220
PIHOLE_DNS_7=2620:119:35::35
PIHOLE_DNS_8=2620:119:53::53
PIHOLE_DNS_9=1.1.1.1
PIHOLE_DNS_10=1.0.0.1
PIHOLE_DNS_11=2606:4700:4700::1111
PIHOLE_DNS_12=2606:4700:4700::1001
PIHOLE_DNS_13=168.95.192.1
PIHOLE_DNS_14=168.95.1.1
You'd usually pick upstreams based on certain properties, like resolution speed, or if they'd not log your DNS activities, or if they would offer DNSSEC support, or if they'd apply additional filtering, etc...
Mixing them all together like you did may give you mixed resolution results depending on the actual upstream that Pi-hole would be using for a given DNS query.
You should revisit your selection of upstreams and restrict them to those two or four that best match your personal preferences.
Back to your issue:
Your database would get locked on write access, as a measure to prevent multiple write requests (potentially from different processes) from corrupting your data.
This can happen e.g. if you try to update the database via some UI interaction while pihole-FTL
would be writing to it at the same time. So this is expected to occur at times.
Usually, repeating your UI request after some time should allow it to succeed.
In your case, however, your log shows a peculiar irregularity:
-rw-r----- 1 pihole pihole 887K Jul 5 13:16 /var/log/pihole/pihole.log
-----tail of pihole.log------
Jul 5 13:16:28 dnsmasq[6657]: forwarded gql-realtime.reddit.com to 8.8.8.8
Jul 5 13:16:28 dnsmasq[6657]: reply gql-realtime.reddit.com is <CNAME>
Jul 5 13:16:28 dnsmasq[6656]: forwarded gql-realtime.reddit.com to 8.8.8.8
Jul 5 13:16:28 dnsmasq[6657]: reply prod-3-realtime-lb-840806869.us-east-1.elb.amazonaws.com is 54.209.177.175
Jul 5 13:16:28 dnsmasq[6656]: reply gql-realtime.reddit.com is <CNAME>
Jul 5 13:16:28 dnsmasq[6657]: reply prod-3-realtime-lb-840806869.us-east-1.elb.amazonaws.com is 18.207.82.243
Jul 5 13:16:28 dnsmasq[6656]: reply prod-3-realtime-lb-840806869.us-east-1.elb.amazonaws.com is NODATA
Jul 5 13:16:28 dnsmasq[6657]: reply prod-3-realtime-lb-840806869.us-east-1.elb.amazonaws.com is 34.227.54.142
Jul 5 13:16:28 dnsmasq[6657]: reply prod-3-realtime-lb-840806869.us-east-1.elb.amazonaws.com is 23.20.50.148
Jul 5 13:16:28 dnsmasq[6657]: reply prod-3-realtime-lb-840806869.us-east-1.elb.amazonaws.com is 54.146.39.97
Jul 5 13:16:28 dnsmasq[6657]: reply prod-3-realtime-lb-840806869.us-east-1.elb.amazonaws.com is 34.197.194.240
Jul 5 13:16:28 dnsmasq[6657]: reply prod-3-realtime-lb-840806869.us-east-1.elb.amazonaws.com is 3.228.166.145
Jul 5 13:16:28 dnsmasq[6657]: reply prod-3-realtime-lb-840806869.us-east-1.elb.amazonaws.com is 3.222.24.15
Jul 5 13:16:31 dnsmasq[541]: query[A] BRWDCE99452F787.iis.sinica.edu.tw from 192.168.0.201
Jul 5 13:16:31 dnsmasq[541]: cached BRWDCE99452F787.iis.sinica.edu.tw is NXDOMAIN
Jul 5 13:16:36 dnsmasq[7743]: query[HTTPS] signaler-pa.clients6.google.com from 192.168.0.201
Jul 5 13:16:36 dnsmasq[7744]: query[A] signaler-pa.clients6.google.com from 192.168.0.201
Jul 5 13:16:36 dnsmasq[7744]: cached signaler-pa.clients6.google.com is 142.251.43.10
Jul 5 13:16:36 dnsmasq[7743]: forwarded signaler-pa.clients6.google.com to 8.8.8.8
Jul 5 13:16:36 dnsmasq[7743]: reply signaler-pa.clients6.google.com is NODATA
Over a timespan of 8 seconds, there are five different PIDs involved (6656, 6657, 541, 7743 and 7744).
By itself, this may not be unusual, as Pi-hole could have forked processes to handle the queries in parallel.
But together with your observation, it may also suggest that there may be multiple unsolicited instances of pihole-FTL
running at the same time.
Run from your Pi-hole machine, what's the output of:
sudo ps -eF | grep "PID\|pihole\|dnsmasq"
And certainly not related to your issue, but you should check your router's IPv6 DNS configuration (click for more)
Your debug log shows that your RPi hosting Pi-hole has picked up two IPv6 DNS server addresses:
-rw-r--r-- 1 root root 82 Jun 17 08:45 /etc/resolv.conf
nameserver 2001:b000:168::2
nameserver 2001:b000:168::1
Those are IPv6s associated with dns.hinet.net
, operated by Chunghwa Telecom (probably your ISP?).
Chances are your RPi learned them from your router.
If that would be the case, all your network's IPv6 capable clients would be able to by-pass your Pi-hole using those IPv6 DNS servers.
You'd have to stop your router from advertising those IPv6 addresses as DNS servers.
