SQL error and login loop
Synology 920+ DSM 7.2.2-72806 Update 4
Pihole running in a docker container (container manager), here’s the compose file:
version: "3"
services:
pihole:
container_name: pihole
image: pihole/pihole:latest
network_mode: "host"
environment:
TZ: 'Europe/Rome'
FTLCONF_webserver_api_password: 'redacted'
WEBPASSWORD: 'redacted'
WEB_PORT: '8080'
WEB_BIND_ADDR: '10.0.0.3'
DNSMASQ_USER: 'root'
DNSMASQ_LISTENING: 'all'
PIHOLE_UID: '1026'
PIHOLE_GID: '100'
volumes:
  • '/volume1/docker/pihole/pihole:/etc/pihole'
  • '/volume1/docker/pihole/dnsmasq.d:/etc/dnsmasq.d'
    restart: always
Pihole is stuck in a login loop, I’ve seen reports of a space issue and I see a database error in the logs, but I can’t figure out what needs changing.
The instance didn’t use to have a custom UID and GID, setting it didn’t solve any permission warning
https://tricorder.pi-hole.net/1Vkz8WnJ/
