Some Websites Unreachable on Android devices
Hey I am using a Pi-Hole on a Raspberry Pi 4 Model B using the default BookWorm Lite OS, following this tutorial
(I was also trying via a docker install and over wifi on the pi before and encountering the same issues, but since have done a clean install and reboot)
I manually set the DNS on my android phone to that of the piHole (192.168.0.139)
All websites load as expected
Websites such as duckduckgo.com and speedtest.net do not load (even if the pi-hole has no block lists and/or it is temporarily disabled)
But other sites Google, Netflix etc seem fine.
jMLtTbT2
Hey I have since managed to resolve my issues. In case someone else finds this thread in the future, here is what helped me.
My problem was that I was setting my gateway IP incorrectly (192.168.1.1 when it should have been 192.168.0.1)
Thanks anyway to those of you that run this site. :slight_smile:
