Some devices with no internet
Hello,
Please see link to my debug logs. My devices (laptop, TV) are connected to wifi but with NO internet. When I disable blocking from Pi-Hole, the devices connect to the internet. Here's the head scratcher, my work laptop, phone, etc.. are connected to wifi with internet access. Any assistance is greatly appreciated.
https://tricorder.pi-hole.net/ObyFQjWm/
From your debug log, no port 53 traffic is being processed by the Pi:
[✓] upresvonver.000webhostapp.com is us-east-1.route-1.000webhost.awex.io.
145.14.144.64 on lo (127.0.0.1)
[✓] No IPv4 address available on eth0
[✗] Failed to resolve upresvonver.000webhostapp.com on wlan0 (192.168.1.2)
[✓] doubleclick.com is 142.250.176.14 via a remote, public DNS server (8.8.8.8
From a client that you believe should be connected to the Pi-Hole for DNS, from the command prompt or terminal on that client (and not via ssh or Putty to the Pi), what is the output of
nslookup pi.hole
nslookup flurry.com
nslookup flurry.com 192.168.1.2
I enabled blocking on PiHole. On laptop giving me issue. I went to aol.com and I get a statement this device is blocked by access control in the router (pi-hole)
nslookup pi.hole
server: 192.168.1.1
address: 192.168.1.1#53
non-authoritative answer:
address 192.168.1.22
nslookup flurry.com
server: 192.168.1.1
server: 192.168.1.2
address: 192.168.1.2#53
Blocking Enabled:
https://tricorder.pi-hole.net/pRI0NabC/
Have you ventured into the "group management" and clients areas?
Good morning Low_Rider,
No I haven't. All I see:
Groups: Default > enabled
Clients: No data available in Table
And just to completely waste your time reading this: is aol is your blacklist, or is it being blocked by the gravity database in the query log? I assume no, because that would be very visible.
So do I understand that it thinks this website is .22? I would guess this is a dns resolution issue.
Negative, AOL is NOT on my blacklist or being blocked (verified on PC and phone) w/ Pi-Hole blocking enabled. yeah it's weird that it's blocked by my netgear router
Disregard above use case
New use case:
Update macOS > unable to connect to internet (When Pi-Hole blocking is enabled).
When I disable blocking in Pi-Hole, I'm able to view the latest update for Mac.
From the Mac terminal, what is the output of the following command:
scutil --dns
After unplugging Raspberry PI/Pi-Hole, reverting DNS settings in router to Get Automatically from ISP, the following results are:
DNS configuration
resolver #1
nameserver[0] : 192.168.1.1
if_index : 6 (en0)
flags : Request A records
reach : 0x00020002 (Reachable,Directly Reachable Address)
resolver #2
domain : local
options : mdns
timeout : 5
reach : 0x00000000 (Not Reachable)
order : 300000
resolver #3
domain : 254.169.in-addr.arpa
options : mdns
timeout : 5
order : 300200
resolver #4
domain : 8.e.f.ip6.arpa
options : mdns
timeout : 5
order : 300400
resolver #5
domain : 9.e.f.ip6.arpa
options : mdns
timeout : 5
order : 300600
resolver #6
domain : a.e.f.ip6.arpa
options : mdns
timeout : 5
order : 300800
resolver #7
domain : b.e.f.ip6.arpa
options : mdns
timeout : 5
order : 301000
DNS configuration (for scoped queries)
resolver #1
if_index : 6 (en0)
flags : Scoped, Request A records
ugh... when I enable pi-hole > add pi hole to dns server in router. Pi hole is warning me that DNS is not in use with an error.... FML I hate networks
What is the output of this command with Pi-hole in the loop and your DHCP server assigning Pi-hole as DNS?
After you make the change, renew the DHCP lease on the Mac: System Preferences > Network > Advanced > TCP/IP > renew DHCP lease
There was a problem applying your settings.
Debugging information:
PHP error (2): fsockopen(): unable to connect to 127.0.0.1:4711 (Connection refused) in /var/www/html/admin/scripts/pi-hole/php/FTL.php:47
DNS configuration
resolver #1
if_index : 6 (en0)
resolver #2
domain : local
options : mdns
timeout : 5
order : 300000
resolver #3
options : mdns
timeout : 5
order : 300200
resolver #4
options : mdns
timeout : 5
order : 300400
resolver #5
options : mdns
timeout : 5
order : 300600
resolver #6
options : mdns
timeout : 5
order : 300800
resolver #7
options : mdns
timeout : 5
order : 301000
resolver #1
if_index : 6 (en0)
Fresh debug token in this configuration please.
[✓] ** FINISHED DEBUGGING! **
  • The debug log can be uploaded to tricorder.pi-hole.net for sharing with developers only.
    * Error message: curl: (6) Could not resolve host: tricorder.pi-hole.net
Latest Token:
iof8DjpR
New token after observing 'this device is blocked by access control in the router.' by visiting aol.com
7dxlrPWV
At this point, is there a way to reset Pi-Hole to factory defaults?
