All devices show in settings with DHCP lease
2 devices on network not appearing in DHCP lease list in settings
Devices are 2 Pi's connected via ethernet, static ips set on each device individually
Devices show some stats in the dashboard
2qwj9xhga2
RamSet
September 17, 2018, 10:38pm
2
Your IPs on those devices are static. They will not show there because there isn't a lease assigned to those MAC addresses.
Those clients never send a DHCPREQUEST
to the DHCP server (due to the fact that they are FIXED IPs) and thus, no lease is assigned.
Ah ok, makes sense
Is there a means to name the device then?
So I see a hostname in the stats rather than just an IP?
RamSet
September 17, 2018, 10:45pm
4
You could edit /etc/hosts
and add THE.DEV.ICE.IP NameYouWant
and reboot the device.
That will populate the name in the stats and not the IP.
On my pihole device of the devices that show no hostname?
Example from one
127.0.0.1 localhost
::1 localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
127.0.1.1 media-pi
RamSet
September 17, 2018, 10:50pm
6
You would edit the file, on your Pi-hole device.
Ok thanks, so I edit /etc/hosts
on my pihole, add
192.168.0.66 media-pi
And then reboot the media-pi?
RamSet
September 17, 2018, 10:57pm
8
Well, are your queries showing up as originating from 192.168.0.66 or 127.0.0.1 (localhost) ?
Stats in the dashboard show the IP of media-pi, i.e. 192.168.0.66
Ok, I done this, rebooted media-pi but it won't boot.
No idea why, and it's too late to look at it....doh.
(I know it's not related to Pi-Hole!)
system
Closed
October 8, 2018, 11:12pm
12
