Just installed Pi-hole on an old modelB-rev1 with 256MB(?) ram on 32gB SD card (8% used)
Router is a tp-Link AX3000 4-stream wifi-6
- Operating System = 32-bit Raspbian GNU/Linux 13 (Trixie) OS-lite version
- new install of OS, then ran sudo apt update && sudo apt upgrade
- then installed using sudo curl -sSL https://install.pi-hole.net | bash
- nothing else is running on the pi
- RaspController app actually reports RAM as 173Mb with 68Mb as spare - pihole debug log also says memory 173MiB System memory
Everything installed OK - set the router DNS to the pi-hole static IP
Pi-Hole console seems to be working fine with queries being shown & graphical display etc
However after loading a couple of web-pages I start getting DNS address not found
Switch back to the router's original DNS addresses (not pi-hole) and it all works OK again
Switch back to the pi-hole DNS ip and then start getting DNS address not found after loading a couple of successful pages
Running nslookup from the laptop command prompt returned this - DNS timeout without the pihole IP, but works with the pihole ip
C:\nslookup google.com
DNS request timed out.
timeout was 2 seconds.
Server: UnKnown
Address: 192.168.1.254
C:\nslookup google.com 192.168.1.95
Server: pi.hole
Address: 192.168.1.95
Non-authoritative answer:
Addresses: 2a00:1450:4009:c17::65
2a00:1450:4009:c17::71
2a00:1450:4009:c17::8a
2a00:1450:4009:c17::8b
142.251.30.113
etc...
Further {edit} used Google AI which said to
- leave the router's WAN/Internet DNS to "Get Automatically from ISP"
- in the DCHP settings, set primary DNS to pi-hole leave secondary DNS blank
- nlslookup now returns this - with pi.hole as the server, not the router
nslookup google.com
Server: pi.hole
Addresses: 2a00:1450:4009:c17::8b
etc
Any ideas?
So my DCHP changes look to have fixed it
- it would be great if someone with a bit more understanding could confirm this is now correct ...TIA
Cheers, G
{edit} - suspected it might be RAM size issue (free -h showed 1.7Mi with corresponding 1.7Mi swapfile size, so I've increased the Swap size to 1.0Gi (and rebooted) hoping that might help, but still getting DNS address not found {/edit}
