This was first posted in the Pi-Hole community on reddit.
https://www.reddit.com/r/pihole/s/cKFFuah1sO
First off, I'm a returning Pi-Hole user. I had a Pi-Hole on a Raspberry Pi 4B for about half a year back in 2020, but then the Pi died and I couldn't get a replacement at a reasonable price. So my Pi-Hole skills pretty much have atrophied all the way. ![]()
So last week I finally pulled the trigger on a new Pi 5 and when it arrived yesterday, I installed a fresh Raspberry Pi OS (64bit; lite; Linux pihole 6.1.74-v8-16k+ #1725 SMP PREEMPT Mon Jan 22 13:38:39 GMT 2024 aarch64), updated everything (including rpi-update and rpi-eeprom-updateto enable NVMe boot) and then installed Pi-Hole (v5.17.3; FTL V5.24; WebUI V5.21). Then I added some block lists, made Pi-Hole the DNS and DHCP server on my LAN.
To clarify:
This was a fresh SD card with the latest image of Raspberry Pi OS, written on the card with Raspberry Pi Imager. After everything worked (at least seemed to), I copied the SD card image to an NVMe SSD and that's what I'm running right now (on a Geekworm x1001 NVMe to PCIe board, no SD card).
The other services on that Pi (Syncthing and Samba) are working flawlessly.
Then I waited for about 12 hours and when I checked on the Pi-Hole, almost all clients had switched to the Pi-Hole as their DNS and about 15% of all queries to that point were blocked.
So, naturally I was curious to see what kind of queries there were, but the WebUI only shows me empty query lists (both in the blocked queries view and the total queries view).
The blocked queries view should have contained about 1500 queries by that time, but it's empty.
/etc/pihole/pihole-FTL.db is exactly 80Kb and doesn't change in size although the "last change" date/time gets updated every minute.
For a moment I thought there might be a bug in the theme I had selected, but by now I have tried all themes that came with the standard installation, but the problem remains the same.
Here's my latest debug token:
https://tricorder.pi-hole.net/04rtFhTz/
Does anybody have an idea what else I could check / do?
