BstAA
1
After Installation of FTLDNS explained in Help Us Beta Test FTLDNS Version info should show FTLDNS branches
Even after reboot I get
- Pi-hole Version v3.3.1
- Web Interface Version v3.3
- FTL Version v3.0
87ar4ma729
It seems that
It seems that the branch fetch didn't work … i.e. a red ✗ when running
"pihole checkout core FTLDNS"
Result:
[✗] Fetching branches from https://github.com/pi-hole/pi-hole.git
In order to switch to FTLDNS you need to execute these 3 commands:
echo "FTLDNS" | sudo tee /etc/pihole/ftlbranch
pihole checkout web FTLDNS
Do you experience any errors when running those commands?
BstAA
3
No error message but a missing o.k.
See my edited post
Can I create a log-file for "pihole checkout"?
You get that every time you try to checkout FTLDNS ?
BstAA
5
Yes. Tried it for six times now
WEB-Access to GitHub is o.k.
You can get debug output of the script by running.
bash -x pihole checkout core FTLDNS
To write it to a file:
bash -x pihole checkout core FTLDNS > /tmp/coreDebug 2>&1
bash -x pihole checkout web FTLDNS > /tmp/webDebug 2>&1
How does this behave?
cd /etc/.pihole
git fetch -v
edit: git status
and git pull
maybe interesting to see too
diginc
10
Good thinking, run commands with sudo just to be safe. (sudo bash -x pihole checkout core FTLDNS
and sudo git fetch -v
BstAA
11
Can't upload Attachements … send logs as Images?
Find the logs here Git.Logs
and coreDebug
RamSet
12
try changing the localization from Germany to English (GB or US) by using
sudo raspi-config
and select localization options
and then change locale
to
Remove your DE setting. Save the settings, then
and try the FTLDNS branch again after.
diginc
13
I upped your user level by 1 so you maybe able to attach files now, if level 1 is high enough (I'm unsure, new to discourse moderation).
BstAA
14
o.k. I'll try.
I just tried changing to dev branch. That worked:
- Pi-hole Version vDev (development, v3.3-312-gb087888)
- Web Interface Version vDev (devel, v3.2.1-263-gbd49d7f3)
- FTL Version vDev (development, vDev-967588c)
BstAA
15
At least startet
"[✓] Switching to branch: 'FTLDNS' from 'refs/heads/development'"
Thanks for help!
By the way
Topic should be changed to "solved" and hint to dependency on locale added.
system
Closed
16
