[SOLVED] Dashboard shows IPs instead of hostnames for clients
[SOLVED: The config below works, but it took a few restarts and 'just waiting' for names to start appearing]
Yes, this sounds like a duplicate post to others, but I've read dozens and none of them have helped since I don't want to manually edit the hosts file in my pihole docker... I want the names to be automatically pulled from the DHCP server.
Configuration:
  • DHCP Server
    • Unifi USG
    • 'register client hostname from DHCP requests in USG DNS forwarder' enabled
    • WAN DNS servers pointing to cloudflare
    • DHCP Name Server option set to the IP address of the PiHole as primary, and the USG as the secondary
  • Pi-hole
    • Docker container on a Synology, with the container network mode set to host
    • PiHole DNS upstream DNS server set to the USG so local domain name resolution works (I have multiple subnets with different domain names)
    • Conditional Forwarding is enabled, with the local network CIDR set to cover all my in-use network ranges, and the DHCP server IP address set to the USG, and the optional domain name set to the match the one used by my primary network
    • Verified that /etc/resolv.conf on the PiHole shows the nameserver set to my USG and the domain set to the primarly local domain
Things that work:
  • From a client machine
    • pinging any local machine by its name.domain works correctly for all my domains
    • nslookup name.domain shows that the pihole is responding and correctly gives the name and address, again for all my domains
  • From bash on the pihole container
    • ping name.domain for machines in any domain
    • nslookup name.domain works
    • nslookup ip.ip.ip.ip correctly responds with ipipipip.in-addr.arpa name = name.domain.
The "Dashboard : Top Clients (total)", "Long-term data : Top Clients", and other relevant UI elements should show local host names instead of IP addresses.
IP Addresses are shown.
https://tricorder.pi-hole.net/27G28W4C/
What Docker image are you using that has nginx as the web server?
Server: nginx
I'm using the official pihole image: https://registry.hub.docker.com/r/pihole/pihole/
Interestingly enough, host names have started appearing on "Dashboard : Top Clients", "Dashboard : Client acitivity over last 24 hours" and "Query Log", but not "Long-term data : Top Lists : Top Client" or "Long-term data : Query Log : Recent Queries"...
I haven't changed any configs since posting, but I have stop/started the container a few times over the past hour.
Host names are not stored in the long term database, and won't appear in the long term data.
Okay, thanks for the info!
Since things magically started working after restarting multiple times, I'm going to go ahead and close this post out.
