[SOLUTION] Pi-hole v6 on Ugreen NAS (UGOS Pro) — port 53 conflict with dnsmasq
Hi everyone,
After hours of troubleshooting I finally solved the Pi-hole DNS failure on Ugreen NAS.
Sharing this because I saw many users with the same issue and no clear solution.
System: Ugreen NAS running UGOS Pro (confirmed on multiple models)
Symptom:
Pi-hole starts, web panel loads, but shows "DNS server failure" and no device gets DNS responses.
Logs show:
CRIT: Error in dnsmasq configuration: failed to create listening socket for port 53: Address in use
Root cause:
UGOS Pro runs dnsmasq instances that occupy port 53 before Pi-hole can bind to it:
  • Virtual Machine app (libvirt) creates instances on 192.100.0.1:53 and 192.100.1.1:53
  • The base system runs its own instance on 127.0.0.1:53
Confirm with: sudo ss -tulpn | grep :53
Solution:
  1. Uninstall the Virtual Machines app from UGOS App Center (if you don't use VMs)
  2. Stop and disable the system dnsmasq:
    sudo systemctl stop dnsmasq
    sudo systemctl disable dnsmasq
  3. Restart Pi-hole:
    sudo docker compose down && sudo docker compose up -d
  4. Fix NAS DNS permanently:
    echo "nameserver YOUR_NAS_IP" | sudo tee /etc/resolv.conf
    sudo chattr +i /etc/resolv.conf
Working docker-compose.yml:
services:
pihole:
container_name: pihole
image: pihole/pihole:latest
network_mode: host
cap_add:
  • NET_ADMIN
  • NET_BIND_SERVICE
    environment:
    TZ: America/Lima
    WEBPASSWORD: 'your_password'
    FTLCONF_webserver_port: 8090
    FTLCONF_dns_listeningMode: single
    FTLCONF_dns_interface: eth0
    volumes:
  • /volume1/docker/pihole/etc-pihole:/etc/pihole
  • /volume1/docker/pihole/etc-dnsmasq.d:/etc/dnsmasq.d
    restart: unless-stopped
Note: UGOS uses port 80, so set a different port for Pi-hole web interface with FTLCONF_webserver_port.
Note: If WEBPASSWORD doesn't apply on first start, reset it with:
sudo docker exec -it pihole pihole setpassword your_password
Hope this helps. Confirmed working on UGOS Pro.
This variable is invalid.
You need to use the correct one: FTLCONF_webserver_api_password
YOUR_NAS_IP should be substituted with the actual IP of your NAS, I presume, which would have your NAS use Pi-hole for DNS.
On the machine that runs Pi-hole, it would be recommended to use a public DNS server IP in addition or instead of Pi-hole, so OS updates as well as Pi-hole's update and repair scripts would be able to run even if Pi-hole would be inoperational.
I also notice that you try to prevent updates to resolv.conf by making it immutable. You should note that processes with elevated privileges may still alter that file.
The contents of /etc/resolv.conf is typically controlled by some tool, as usually indicated by a comment in that file. You should configure that tool to persist changes to your resolv.conf, rather than editing it manually.
You may want to investigate the proper way of populating /etc/resolv.conf on your NAS.
Sometimes you might want to use the mask option here too because some services are very stubborn and ignore your settings after a reboot :frowning:
See here : systemctl(1) - Linux manual page
mask UNIT...
           Mask one or more units, as specified on the command line. This
           will link these unit files to /dev/null, making it impossible
           to start them. This is a stronger version of disable, since it
           prohibits all kinds of activation of the unit, including
           enablement and manual activation.
Just in case you need it...
Thanks for the correction! I've updated the compose file to use FTLCONF_webserver_api_password instead. Confirmed it works correctly on first start without needing to reset manually.
Thanks for the detailed feedback!
You're right about the DNS fallback. I've updated /etc/resolv.conf to include both Pi-hole and a public DNS as backup:
nameserver 192.168.xx.xx
nameserver 8.8.8.8
Regarding chattr +i, noted — it's not the ideal method. I'll investigate the proper way to persist changes on UGOS Pro. For now it's working but I understand it's not bulletproof.
Good tip on mask! I've applied it:
sudo systemctl mask dnsmasq
Much safer than just disable to prevent it from coming back after UGOS updates. Thanks!
