Sneak peaks for updates in lighttpd?
@rdwebdesign , do you have more details or a sneak peak regarding lighttpd.conf coming with "the next update" (which one will it be?)…?
Rather than commenting about some upcoming release, rdwebdesign was just transcribing the prominent warning right at the start of lighttpd.conf:
#     FILE AUTOMATICALLY OVERWRITTEN BY PI-HOLE INSTALL/UPDATE PROCEDURE.     #
#              CHANGES SHOULD BE MADE IN A SEPARATE CONFIG FILE:              #
#                         /etc/lighttpd/external.conf                         #
What I meant is if you make any changes directly on the lighttpd.conf these changes will be overwritten on every Pi-hole update.
