When I request a website it starts to load within a second.
Many websites take about 10-20s to load, including www.google.com, www.facebook.com. When going to these a second time (having closed the page) they load nearly instantly. After 10 minutes or so the slow behaviour can return. Other websites are unaffected and load nearly instantly.
I have just setup Pi-hole on an old RaspberryPi 1 connected to me router which I changed the Primary DNS Observing the log in real time I have seen slow queries for both [AAAA] and [A] requests.
I have read various pages about this issue that suggest adding entries to iptables but these were all for <v4.0 . As far as I understand this had been resolved in newer versions and no longer necessary. Is this true or should I still try the suggestion on https://pi-hole.net/2018/02/02/why-some-pages-load-slow-when-using-pi-hole-and-how-to-fix-it/ ? If not, can you suggest anything else to try?
Error: Load timeout for modules: version!libs/ads/bidbarrel http://requirejs.org/docs/errors.html#timeout [require-2.1.2.js:6:932](https://cnet2.cbsistatic.com/fly/js/libs/require-2.1.2.js)
makeError https://cnet2.cbsistatic.com/fly/js/libs/require-2.1.2.js:6
C https://cnet2.cbsistatic.com/fly/js/libs/require-2.1.2.js:6
s https://cnet2.cbsistatic.com/fly/js/libs/require-2.1.2.js:6
I had one computer with nothing, just standard firefox, and the other with Ad Block Plus. They both exhibited similar behaviour. I've now turned off ABP and some websites are still very slow to load. I have captured a log file which shows a 21 second delay between the following consecutive entries
query[A] www.twitter.com from *my router*
forwarded www.twitter.com to 1.0.0.1
followed by another 104 entries in the same second.
During this period the desired webpage is blank.
Could the pi's processor load running continuously at over 1 (between about 1.3 and 2)? This is on a fresh install of Raspbian Buster with nothing else than pi-hole running.
sounds like there is something else going on with your device and network.
21s is ridiculous for DNS requests. There is a chance your router is causing the delay in some way as it would appear to be doing a DNS relay of some kind.
also in terms of CPU load i have 3 or 4 services running and rarely get above 0.1 in terms of loads
I had the same issue for a period of time, but I couldn't find what was behind that. Since i have unbound installed and Pihole is working with it, the slow-loading-effect is gone.
This can be due to obsolenscence of browsers chached data (DNS and content). Once a site was successfully connected and loaded, it is "known" for the browser, but after a period of time the browser will declare these data as obsolete and will reload parts or everything when you visit the site again.
