Skype connection failed
Hey Guys,
i cant login with my Skype Client. No connection, i cant start chats or anything else.
What can i do?
Connect to your pi and copy this in your terminal:
pihole -w s.gateway.messenger.live.com ui.skype.com pricelist.skype.com apps.skype.com m.hotmail.com s.gateway.messenger.live.com sa.symcb.com s{1..5}.symcb.com
and then press enter.
very nice!!! it works. thx u guy.
Please see also commonly whitelisted domains.
Note the in such a situation you can always go to the Query Log to investigate which domain has been blocked at the time you used Skype. You can use the Whitelist buttons there to permit all those queries, so you don't have to search around a lot.
