I noticed that when a site is blocked by one of the block-lists, it can still be accessed when a user enters the name of the site in a search engine and then just clicks on one of the resulting links to the site. Is this normal behavior ?
Can you post an example with the URL's that are being retrieved? And please include applicable parts of the tail of your Pi-Hole log if you can. Thanks.
I found the reason I think. The site is in the blocklist with name zzzzzz.com , and when you search for it in google it returns a link to www.zzzzzz.com which is then not blocked. Does a blocklist need to have the www prefix for it to work ? Or does it automatically detect and block anything ending with zzzzzz.com ? Is this about the limitation that block lists cannot have wildcards ?
