Siasky.net blocking
No blocking enabled, but one client keeps getting blocked going to siasky.net.
All blocking is disabled, plus the blocklist is null (no blocklist at all). I would expect no blocking to happen.
Several times a day, one client will get blocked going to siasky.net. Googling siasky, it appears to be some kind of cryptocurrency malware.
(moderator edit: explicit debug log removed)
(For your own privacy and security, please do not post your full, unsanitised debug log.
We just ask for the token.
siasky.net is either not resolvable at all or blocked by at least one of the upstream DNS servers, as demonstrable running dig siasky.net @9.9.9.11.
If an upstream would reject a query as blocked, that would show up as Blocked (external) in Pi-hole's Query Log.
Yes. The log entry calls it:
" Query Status: **Blocked (external, NXRA) Reply: NXDOMAIN"
which indicates it is being blocked by an upstream server; not pihole itself.
I presume there is something causing the query to happen on my computer, but all the malware scanners I've run have not found the source.
