Is there a way to show the dashboard graph using historical information? I was looking at the dashboard and saw a peak a couple of days ago, then saw the peak again this morning and I was wondering if there was a way to (or will be) to change the range the plot shows from the last 24 hours to say 72 or even further back?
already been opened I think...
https://discourse.pi-hole.net/t/long-term-statistics-for-pi-hole/1914
Thank you. I would agree with you on keeping the current dashboard like it is. It would be good (maybe in the Tools section) to be able to look at the dashboard data going back a longer period of time or as mentioned between two dates.
Looking forward to seeing what is developed.
I believe that the graph is using info from the logfiles? Think you can create a script to parse the logfile daily and append to a file that you can then analyse. Not as fancy but it will give you then info you want...
The dev branch currently includes support for viewing long term data (pihole checkout dev). We're getting ready to release this soon (tm).
