Setup with Unbound vs Dnscrypt
I setup PiHole recently, and all's working fine. I went to the website of PiHole and followed the tutorial for Unbound setup, and that's working fine too.
I think my ISP is blocking some of the DNS requests, so I want to setup encrypted DNS requests.
Correct me if I'm wrong, but if I'm using unbound as a recursive DNS resolver, there's no way I can do "encrypted dns", since they "have to be" in plain, as upstream might not support DoH or DoT. So, my solution would be to point PiHole to DoH or DoT server (such as dnscrypt-proxy2) and point that to upstream recursive server, or my own hosted recursive server which runs Unbound, correct?
Why do you think this? What replies do you see that support this assertion?
I can visit a few websites through Firefiox with DoH enabled, but not with it disabled
What would be the correct approach? Is my reasoning correct?
did you try the command dig <url here> from the command line?
Additionally, did you try pihole -q <url here>?
Yeah. I tried some domains without pihole, and pihole + unbound. Both give me the same response. Same if I try to load the website with Firefox. But, if I enable DOH on Firefox, I can reach those domains again.
So,
  • pihole + unbound doesn't work
  • pihole + dnscrypy (upstream as cloudflare) works
  • Normal network without pihole etc doesn't work
  • Firefox on normal network + DOH in firefox works
But the main clarification I seek is,
  • Unbound can do DOH or DOT with an upstream recursive dns server, or, itself serve as a recursive DNS resolver, but without encryption, correct?
Correct. The authoritative servers don't do DOH or DOT (learned that myself on these forums a while ago :slight_smile: )
Substitute domain name for URL.
Pi-hole works with domains, not URLs.
Depending on your version of unbound. All versions that ship with supported distributions can do DoT, but only newer versions (since 1.12) can do DoH.
Debian Buster ships with 1.9.0, for example.
My bad, I meant just that!
Yeah so I guess unless tech catches up, I'll either have to setup my own recursive DNS resolver somewhere in the cloud, and DoT/DoH to that, or just hand it over to [insert providers]
Even when setup as a recursive DNS resolver?
When setup as a recursive resolver, unbound does no encryption. The nameservers don't support it.
Yeah that's what I was looking for haha. Thank you for clearing that up!
So if I setup a cloud server upstream for recursive DNS, how do I secure it? To prevent DNS poisoning and other forms of attacks? Want to learn a bit about it. (I guess this part is off topic, if so, please do let me know : ) )
Enable DNSSEC.
It is the only way to determine whether DNS records are authentic and have not been tampered with by cryptographically signing and verifying the records.
All root servers and >90% of tld servers support DNSSEC, while support in lower level domain servers is still improving.
Is there any way I can check if DNS requests were blocked? For example when I setup a recursive server on a cloud?
