[✓] FTL is listening on port 53
[✓] UDP (IPv4)
[✓] TCP (IPv4)
[✓] UDP (IPv6)
[✓] TCP (IPv6)
[i] Pi-hole blocking will be enabled
[i] Enabling blocking
[✓] Pi-hole Enabled
Pi-hole version is v5.15.3 (Latest: v5.15.3)
AdminLTE version is v5.18.3 (Latest: v5.18.3)
FTL version is v5.20.1 (Latest: v5.20.1)
Container tag is: 2023.01.10
sudo: effective uid is not 0, is /usr/bin/sudo on a file system with the 'nosuid' option set or an NFS file system without root privileges?
